Ir para o conteúdo principal
The B15 from Caterpillar is an Android based smartphone featuring a rugged, durable design and a fairly long battery life. Released in early-mid 2013, the B15 features a 4” LCD display, 2000 mAH Li-Ion battery, and ships with Android 4.1.
Why cant I move my apps from main storage onto a sd card
When for instant i download an app it will say low storage memory even tho i have a sd card inserted but when i go into apps and try to move it onto my sd card it wont allow it there are no option for moving onto sd card only internal storage and main storage is displayed and im sick off it i have tried moving the app files onto the sd card via a computer but then when i insert it back into my device and try to run the app it will say app not installed please help thanks.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Only certain apps can be moved, to be specific, all apps that are not included with the phone can be moved. It is also possible the SD needs to be reseated or replaced. Good luck!
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Filip Zak será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 16
Ao todo: 139
