Ir para o conteúdo principal
The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
1185 Perguntas Visualizar todos
Liquid Damage reparable? Pictures attached
hello guys,
my mbp r 2015 wouldnt start up. i detected a damaged backlight connector and pulled the logicboard out of the bottom case.
there seems to be a burnt area - is this reparable?
pictures : https://imgur.com/a/3eCs2
thanks in advance
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
Pretty sure that can be fixed. I would just need to harvest the connector then solder it. Probably would have to make a jumper or 2. Would you feel comfortable with the repair yourself? You would need some microsoldering equipment and a microscope.
Esta resposta foi útil?
Pontuação 1
do i have to replace the damaged connector? i wouldnt mind to use the mbpr keyboard without the backlight?
i will use alcohol to remove the corrosion - is there more that i can do?
Pontuação 0
Adicionar a sua resposta
M Ro será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 108
