Ir para o conteúdo principal
How do I connect my device to the internet?
I want to connect to the internet, but I'm not sure how to do so wirelessly.
Esta é uma boa pergunta?
Pontuação 0
1 comentário
still unable to connect,used alexa app
por
Adicionar um comentário
3 respostas
Solução escolhida
You connect your Amazon Echo Dot through the Alexa app! Go to settings, select your device, and select set up wifi! I am attaching a link which will give more help on connecting your device to the web.
https://www.amazon.com/gp/help/customer/...
Esta resposta foi útil?
Pontuação 0
Pergunta mais útil
Connect echo dot device to Wi-Fi network:
Go to Settings option from the left navigational panel.
Select your device and after select update Wi-Fi.
Try to press and hold action button when the light ring changes to an orange and select Wi-Fi network, enter the password.
Also, Make sure enter password is right to connect to the network.
Pontuação 1
If you want to connect echo dot to a Wi-Fi network, follow the instructions in the Alexa app. Most important thing that is echo dot connects to dual-band Wi-Fi (2.4 GHz/ 5 GHz) networks that use the 802.11a / b / g / n standard. Echo Dot does not connect to ad-hoc (or peer-to-peer) networks.
To learn more, go to '''Connect Echo Dot to Wi-Fi'''
Pontuação 0
Adicionar a sua resposta
Cassidy O'Connor será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 31
Ao todo: 6,984
