Ir para o conteúdo principal
Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
586 Perguntas Visualizar todos
Progress bar on start up screen stuck and screen is frozen.
When turning on my computer, the progress bar on the white startup screen with the apple logo in the center, gets stuck 3/4 of the way and the screen freezes. I tried option-command-p-r and was not successful. Thanks for your help!
Esta é uma boa pergunta?
Pontuação 2
2 comentários
I had a ѕіmіlаr issue, when turning on my Mасbооk Prо used to freeze.
During startup the progress bar would get stuck.
Fіnаllу I mаnаgеd tо rеѕоlvе thе рrоblеm.
Follow thіѕ ѕоlutіоn hеrе: http://bit.ly/MacBootStuck
Hоре thіѕ hеlрѕ
por
The link provided above for its solution does not work. Please kindly update.
por
Adicionar um comentário
2 respostas
Solução escolhida
That's about where the GPU driver kicks in. See if it will boot in Safe Mode (hold down the Option key On start up). What OS X are you running?
Esta resposta foi útil?
Pontuação 4
3 comentários:
We are not sure...
por
OK, what did it do in Safe Mode?
por
While it is in Safe Mode, you should also run Disk Utility and run "Repair Permissions" if it exists, and "Repair Disk".
por
I ' ve done it. But it doesn't work
Mise à jour (13/01/2018)
Wath's the next step. Please. Thanks for helping
Pontuação 0
Adicionar a sua resposta
Kathy será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 44,958
