Ir para o conteúdo principal
The Sony Extra Bass Headphones Model: MDR-XB450AP, are a high end pair of headphones that are manufactured by Sony. Features an omni-directional microphone for Bluetooth capabilities.
Why my right ear not working?
I checked for the driver wires ,if it is disconnected or not .But its fine .But no sound from right *
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
sounds like there is a break in the cable that leads to the right ear. try narrowing down where the break is by wiggling the cable all along the length of it. once you have found the break point you will want to replace that section of wire. If that doesnt find them problem it could be that the soldering on the jack or on the driver in the right ear has come loose( happens quite often)
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Akash prasad será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Ao todo: 574
