Ir para o conteúdo principal
The GameCube is Nintendo's fourth console gaming system. Repair is simple and requires only common tools.
Disc not being read
My gamecube is having issues playing one specific game. It will play far enough along to get to the memory screen to create a new memory file but stops spinning. It always stops there and the game itself is in pretty good condition with barely any scratches. Not even my wii gets past that point.
Is there anything I can do to fix this? (Note, my gamecube plays other games perfectly fine, it's just that one game in particular I'm having trouble with.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
It's entirely possible that your particular copy reads poorly at a certain point of the disc. I'm not familiar with the nuances of the Gamecube disc mechanism, but I know in the past I've gotten certain discs that weren't manufactured properly and wouldn't read right (I bought a certain audio CD that was missing the last 5 seconds on every single track and I exchanged it for another disc that did the same, bad disc runs do happen). So if this is the only game you're having issues with (have you had problems with this disc before?), then I suggest finding another copy of the game to try. Usually if it's a problem with the laser mechanism it shouldn't be too hard to find issues with reading other discs, but it sounds like that's not the case here.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
IceWitchofTsurara será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 94
Ao todo: 6,919
