Why is my neato botvac D75 Keep beeping ask to reset on switch?
my Robotic BOTVAC keeps asking to turn on switch ,But does not make a difference on or off? in it resets it needs to charge battery, after done charging it take off and stops ask to turn on or says need to charge battery?
Esta é uma boa pergunta?
2 comentários
I have the same issue. I contacted Neato and worked with their tech department for awhile. Finally the guy said it could be a bad battery and suggested I purchase a new battery. I did that and it is still not working. Just wanted to warn you encase they make that suggestion. I'm going to take mine apart and see if I can see something near the switch.
por mcfarland112
Als de batterij goed is kontroleer de aan uitschakelaar of deze niet defect is.
De Botvac 85 van ons was de aan uitschakelaar defect.
Te bestellen bij Relchelt bestelnr. ss13lsp
Na vervanging werkte de Botvac85 weer perfect.
por Drijver
