Ir para o conteúdo principal
The first iteration of Studio Beats headphones were manufactured by Monster in 2008. They are available in a large variety of colors. Screwdrivers, plastic opening tools, and possibly a soldering kit may be required for repair of this device.
Why is only one side of the headphones working?
My headphones are only playing music normally out of one side of the headphones and the other side is only playing the music very dimly so I can barely hear it. Any suggestions of how to fix?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
the cables for the headphones are so thin(several for each, left/right) and if the headphones are twisted and rolled one or two of the cables are broken so they no longer transmit the signal well.
for a test use them in another device and if you have no problems then it is with the unit you are using them now.
Esta resposta foi útil?
Pontuação 0
2 comentários:
the answer above is good but it didn't include for you to try another headphones in the computer.
Also try the same headphones and wiggle the cable, if you hear the sound in both then it is not computer.
are the internal speakers good?
I have many phones that do that.
por
head set is brand new.
por
Adicionar a sua resposta
Matt Ghering será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 5
Ao todo: 13,379
