Ir para o conteúdo principal
A popular graphic calculator released by Texas Instruments in 1996.
12 Perguntas Visualizar todos
Why is my screen acting weird
So when I want to do the thing where you do a number then enter then add/subtract/multiply/divide then enter multiple times so it goes up by increments (don't actually know what it's called) I can only press enter 5 times and then the screen goes wonky if I try to enter more than that. I don't know the technical terms so this is probly hard to figure out but some help would be great ^~^ thanks
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hey, it sounds like your ribbon cable is failing. This is a common issue and not incredibly difficult to fix. You can find a great guide for it here.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
British Sillyname será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 6
Duração total: 196
