Ir para o conteúdo principal
The Asus X555L is a low budget laptop that came out in May of 2015. The model depicted in these guides is X555LA-SI305041, an Intel Core i3 laptop designed to be affordable for consumers. Similar model numbers: X555LB, X555LD, X555LF, X555LI, X555LJ, X555LN, and X555LP
60 Perguntas Visualizar todos
Asus X555L laptop Flickers When Battery Below 70%
My Asus X555L has been flickering for a long time. I got it about 1 and a half years ago. The problem does not occur when the laptop is plugged in. I have tried all suggestions on the internet with no success. I think it might be a problem with the LCD inverter. Has anybody else fixed this problem before? If so, please help me. It it really annoying.
Edit: see my post at the bottom
Esta é uma boa pergunta?
Pontuação 2
7 comentários
Hi!
Does your laptop also switch to a power-saving mode when it does start to flicker? Or does the luminosity change?
por
I am not put into a power saving mode. The luminosity does not change either. It mostly happens when I press a key or open an app.
por
So if you just leave it running off the batteries will it not start flickering UNLESS you open an app or press a key?
por
Sometimes it does that and sometimes it flickers constantly.
por
I have this exact laptop, so if you need picture of a part or something I can help.
por
Exibir mais 2 comentários
Adicionar um comentário
4 respostas
Solução escolhida
Update: I’ve discovered that the flickering problem most likely has to do with the LCD inverter - the chip that controls the LCD screen. It is definitely not a software problem because it has the same issue when in the BIOS setup and booting a os from a USB drive. Since the LCD inverter is attached to the screen, I would recommend replacing the LCD screen, not the battery. You can find them on Ebay for as little as $43: https://www.ebay.com/sch/i.html?_from=R4...
I think this is a design flaw in this laptop model. I personally would recommend buying a better computer.
Esta resposta foi útil?
Pontuação 2
next time the screen flickers go immediately to the even log and see if an error is recorded . If there is an error this may help shine a light on it . If there is no error code before jumping on the invertor you may want to test your battery . If your battery is getting old it may say 70 % but its may be failing . If the battery dies with less than two hours of use it may be time to replace the battery . bad batteries can cause a lot of different problems and if your not having any screen issues when its plugged in Id tend to look long and hard at the battery. If after replacing the battery you still have no joy then replace the invertor . This is a helpful video towards that end
https://www.youtube.com/watch?v=S87niyGJ...
Some other things to check are the screen cable at the hinges and the screen itself . Hope this helps
Pontuação 1
6 comentários:
The laptop is only 1 and a half years old. I doubt the battery is failing.
por
Even if the problem is the LCD inverter, I can't seem to find one for my laptop.
por
It appears the invertor is integrated into the screen on this laptop
https://www.youtube.com/watch?v=Wm_sLtqk...
This video shows how to replace the screen and if you look closely at the bottom of the screen in the video it says do not touch ... this is were the invertor is . They can be purchased on ebay
https://www.ebay.ca/sch/i.html?_odkw=lap...
por
I think I would rather live with a simple problem then spending $75.
por
Great. Now its starting to flicker when its at 80%.
por
Exibir mais 1 comentário
I have the same problem with a similarly old Asus x555l. If anyone found a solution, please help!
Pontuação 0
i have the same model with i5 and hd 4400, replaced the battery, but nothing changed. Now i have to try with the lcd if this does not fix it, ive lost a lot of money ! :(
Pontuação 0
3 comentários:
i changed the lcd, i didn't want to buy original one and i bought brand AUO it fits perfect. Now the screen of laptop doesn't blink rapidly !
por
My big-screen Toshiba BIG-lap-top, same blinking problem. Linux set normal-brightness 'on battery' from 80% to 50%, and normal-dim from 40% to 15%. Problem not as noticeable ,,, but I did notice the fan is much quieter.
por
Maybe its time to clean ot inside and change the thermal paste. But the problem with the blinking its inverter of the screen.
por
Adicionar a sua resposta
Petabyte Studios será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 30
Duração total: 12,231
