Ir para o conteúdo principal
4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
Using charging port from another iPhone
Is the charging port from the iPhone SE interchangeable with another iPhone?
I need to see if its the SE's charging port thats the issue but I dont have an SE one but I have a 6, 6s, 6 plus and 5c one
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
No, unfortunaly they are not compatible
Esta resposta foi útil?
Pontuação 1
3 comentários:
Is their any thats compatible i.e. the 5S?
por
Only iphone 5s chargingport is compatible with the 5s and the same with SE
por
Unfortunately not. The SE has it's own charging port. It's almost the same as 5S , but the plug is a little smaller on it. So you would have to get one just for the SE to test .
por
Adicionar a sua resposta
Jaymie será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 8
Ao todo: 1,059
