Ir para o conteúdo principal
The flashlight doesn't work
I followed the 'problem' steps from the manual, but the flashlight is still not working.
before it stoped working, from time to time the flash worked, making a popping sound when making a picture.
I think, it is broken and needs to be replaced. but how, do I do that? and were can I find a new flasher?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Your best bet it to put a watch on eBay for a "spares or repair" camera of the same model but with a different fault. It should then be possible to swap out the flash module. You can practice disassembly on the one from eBay before attempting yours.
BUT: make sure you understand the danger from the flash capacitor and how to avoid it - this can hold a charge at a dangerous voltage for many hours, or even days, after being switched off.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
olé kike será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 30
Ao todo: 551
