Ir para o conteúdo principal
Model A1112 / 512 MB or 1 GB capacity
25 Perguntas Visualizar todos
How to replace audio jack port iPod first gen - M9724LL/A
My M9724LL/A audio jack is not working properly when inserted to audio jack port. I don't know how to replace it with the new one and which audio jack port to use. Thank you in advance.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hello,
The audio jack in one of these is soldered to the motherboard. Which means that you would have to desolder and then solder a new one on. Parts for this can be found on eBay but if you don't know how to solder you would have to replace the whole motherboard which is quite hard. This will also remove everything you have on the device as you wouldn't have the same memory.
Here is a guide on how to remove and replace the motherboard and also a replacement part from ifixit:
iPod Shuffle 1st Generation Battery & Logic Board Replacement
iPod Shuffle Gen 1 Logic Board
Hope that helped
Imagem de iPod Shuffle Gen 1 Logic Board
Produto
$9.99
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Abhiraj Singh Rathod será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 4
Últimos 30 dias: 6
Duração total: 311
