Ir para o conteúdo principal
O Seagate FreeAgent Go é um disco rígido externo portátil da Seagate. Foi lançado em maio de 2010.
USB Ports reset when new connection is made with USB
I have a Seagate External 1TB HD that I use with my Asus GL502 laptop. When I plug it in, a notification comes up telling me it's been connected. Great.
When I plug any other USB device into my laptop however (like my logitech headset), the ports reset as if I've just reconnected everything and the notifications show up again, even though I never unplugged them.
This also happens to my mouse.....I don't understand. Please help?
This is most annoying when I am accessing a document or something important for school on the external hard drive, and after plugging in my mouse or headset, the doc/info I have open is no longer available and force closes because the laptop acts as if I've unplugged the HD.
note: this happens with flash drives as well.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
You need to get a cable that has 2 USB on one end.
The problem is that there isn't enough power by itself on the USB hub.
https://www.amazon.com/gp/product/B00MFL...
Check the heads, the link is for a USB 3 type connector, but they make them for other types of connectors. Using this takes up 2 USB ports for the hard drive.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Christian Meier será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 19
Ao todo: 402
