Ir para o conteúdo principal
The DZ09 is a Chinese smart watch with basic features and the ability to make calls. These can be as cheap as $10! (Yes, you read that correctly!)
Touch Screen Not responding
Hello,
My watch turns on and off ok. When I am trying to change the language to English, I am unable to select this choice because the touchscreen does not work at the top or bottom. I am only able to select things in the center of the watch. Can this be fixed?
Esta é uma boa pergunta?
Pontuação 5
Adicionar um comentário
9 respostas
Pergunta mais útil
My y1 smart watch can't respond touch how can I solve this problem .. please help me friends
Esta resposta foi útil?
Pontuação 2
Sir my watch touch not working
Pontuação 1
1 comentário:
Sir please my answer
por
My watch touch screen is broken to me can you change my touch screen
Pontuação 1
So, I am also having problems with my smartwatch, but not this. So, sorry if this doesn't help: Try taking it back to the store you bought it from, and explain to them on what day you got it, where you were and what you did to it before it messed up. If you dropped it in a liquid, for example. Try buying a new one, or getting it repaired at the store. If you got it online, try getting a refund, or get a new one. So, You're welcome if it helped. But sorry if it didn't.
Pontuação 0
Do not started start and close
Pontuação 0
My DJ 09 Smartwatch is started and Firoz start closest are closed in one day is over Water
Pontuação 0
1 comentário:
Can you buy me
por
Touch toot ge
Pontuação 0
I have bought this touch
Pontuação 0
Well the follow video might help you out: https://www.youtube.com/watch?v=9YKnwyJt...
Pontuação 0
Adicionar a sua resposta
YO'LANDA LYNN será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 10
Ao todo: 4,272
