Ir para o conteúdo principal
LG's flagship smartphone, with a unique slide-out battery and detachable I/O module supporting multiple hardware expansion options. Released in April 2016.
146 Perguntas Visualizar todos
Replacement 16mp rear camera is unfocused and "nodding"
The replacement camera focus is stuck and blurry, the quality looks arguably worse, and it "nods".
When I hold the camera still, the camera shifts downwards then back to the centre (when holding portrait-view-- left/right in landscape). You can see the camera lens move if you look directly at it.
I'm not sure what to do to fix this, or did I get a faulty one? When I opened the package, the camera was at the bottom of the box and not cushioned in-between the packing material so could it have been damaged during shipping.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
Hi Kimberly,
That camera sounds like it's damaged, so you should consider returning that one and getting a new one.
- Jasen
Esta resposta foi útil?
Pontuação 2
Hi Kimberly, I had the same problem until I reboot the cellphone with factory settings a few minutes ago. It now works perfectly fine.
Pontuação 0
Adicionar a sua resposta
Kimberly Fong será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 12
Últimos 30 dias: 13
Duração total: 621
