Ir para o conteúdo principal
A primeira geração do Ford Focus foi fabricada na Europa de 1998 a 2004 e na América do Norte de 1999 a 2007.
bypass pat in 2002 ford focus
how do i bypass the pat system in a 2002 ford focus i have removed the key switch because it locked up and wouldn't turn
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
There is no way to bypass it. As long as the transceiver ring around the ignition lock is not damaged , you can buy a new Ignition lock with 2 keys, and either tow it to ford to have the keys programmed or have a lock smith program them.
Esta resposta foi útil?
Pontuação 0
There is a free open source obdII ford specific software called forescan
https://forscan.org/
Works with USB and Bluetooth obdII interfaces
To reprogram keys, you have to register your information in the software, this is to prevent just anyone reprogramming a key and stealing a car.
Pontuação 0
Adicionar a sua resposta
arthurl.browniii será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 19
Ao todo: 3,191
