S8 Phone battery temp to low error
I had to replace the I/O daughter board because of my charging port not working once i did it was working fine but after a night of charging and on the bus the next day i attempted to charge it again and it came back with this warning.
It gave me reason to believe my charger or battery was the issue so i put the old one back in and now it does the same as well
In my research for an answer i have found that it could be the daughter-board with charging or it could be the charging coil and antenna assembly on the back of the phone.
Has anyone else had any luck with replacing the charging coils after this type of error ?
Esta é uma boa pergunta?
8 comentários
Does this video help?
https://www.youtube.com/watch?v=UGu4oouS...
por S W
Let us know how you fix it!
por Israel
amazing help.tnx its work
por hidden hdn
Hello. I did the steps above, but the charge stays constant and does not increase. I tested the battery and charging socket and it's still a problem. Anyone have this problem?
por soroush
i was working on a phone and trying to test it and got this same issue. however, once i attached the wireless charging part, it started working. Here's a video with an example https://www.youtube.com/watch?v=iSVkxNI7...
por Gadget Gator
Exibir mais 3 comentários
