Ir para o conteúdo principal
What is causing my iPhone to have awful wifi and bluetooth?
The wifi and bluetooth on my phone both don't work very well. The wifi has very short range and randomly disconnects, and the bluetooth has trouble connecting and staying connected. I think it might be something at the hardware level, but I don't know for sure
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Im not sure if you have dropped your phone, had water damage, if the problem gradually came on or happened all at once. But I would start by replacing your wifi antenna which is responsible for your Wifi and Bluetooth signal. If this does not correct it, something deeper in the Logic board may be.
iPhone 6 Top Left Antenna
Imagem de iPhone 6 Top Left Antenna
Produto
$9.99
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
redmoncooper será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 99
