Ir para o conteúdo principal
Faild to setup touch ID
When I update my phone to IOS 11 the touch ID always show me ‘unable to complete touch ID setup
-I’ve delet all setting
-return to ios 10
-i’ve not open or fix any thing in the device
New one)
Still not working
Esta é uma boa pergunta?
Pontuação 0
2 comentários
which version of 11 IOS is your phone ?
por
The last one they update it yestarday ios 11.1.1
por
Adicionar um comentário
2 respostas
Solução escolhida
Sometimes I've seen touch ID restarting to work after 3/4 hard resets performed. I ignore the reason behind such behaviour but by experience I'd try that too before surrender.
Esta resposta foi útil?
Pontuação 1
3 comentários:
How can I do it
Is it press home B and power B ?
por
Power button+home button pressed together until it reboots. When you see the apple logo release and let boot normally.
por
I’ve try it 3 times , still not working also it’s gutting more hot
por
Pergunta mais útil
If you are sure nobody has opened the phone and performed unauthorized repairs, only Apple can fix this.
Pontuação 1
3 comentários:
It's not suppurt by apple any more. Because it's old.
por
Yes it is supported, you just need to pay for it.
por
Ammm ok i will check up thanks
por
Adicionar a sua resposta
Kadhem AlShaks será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 12
Ao todo: 6,446
