Ir para o conteúdo principal
This PC is a Dell Inspiron 3000 Series laptop with an AMD processor and a non-touch display. It's model number is 3541.
Dell Inspiron 15 (3000) 3567
How do I remove my HDD to install a SDD? And what measurements does it have to be? 2.5?
Esta é uma boa pergunta?
Pontuação 3
1 comentário
I Also have that type of Computer, I think it's not really About the Measurements, it's about the plugin, and Basically they are all mostly the same.
por
Adicionar um comentário
1 resposta
Solução escolhida
Yes, here is the service manual.
http://topics-cdn.dell.com/pdf/inspiron-...
It appears to be a standard 2.5" laptop hard drive, see page 37.
Esta resposta foi útil?
Pontuação 0
2 comentários:
Thank you very much. I have another question am I able to add another HHD or SSD? I’ve read from my other post that have to remove my optical drive or something like that
por
Correct, if you wanted a second drive, you would remove the optical drive. You would need this adapter.
https://www.ebay.com/itm/2nd-HDD-SSD-HD-...
por
Adicionar a sua resposta
Ryan Montesino será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 12
Ao todo: 7,250
