Ir para o conteúdo principal
iPhone keeps asking to be activated... activation screen keeps coming
ok so this iphone 6 will go through normal set up process...
come time to activate it does so successfully..
then i hit enable location - get started - bam were in the home screen...
after about 1 minute it goes back to the activation screen and that same process just keeps repeating..
i tried to restore it via itunes... and a factory restore and nothing....
what part would i need to take a look at and maybe replace?
Update (11/18/2017)
Thank you but that did not help..... I know what you are talking about but it does not help me....
Anybody on here seasoned enough to answer this??
I ran a check on 3utools and its showing a different model and color than the actual shell which means the board has been swapped before..... im trying to figure out why it wont activate with any sim card inserted..
i even put some from overseas just incase its a over sea phone.....
UPDATE::: 11/18/17
I CHECKED THE ESN AND ITS AT&T.....
I SUBMITTED FOR UNLOCK ON ATT/DEVICEUNLOCK
IM WAITING FOR UNLOCK APPROVAL AND I WILL TRY TO ACTIVATE AGAIN...
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hello
No part is to be replaced
Restore the phone again and insert the simcard and when it’ Activated get the simcard out and complete the process, if it keeps happening try to do it on iTunes
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Claude Katto será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 1,434
