Ir para o conteúdo principal
Lançado em junho de 2012, modelo A1278. Processador Intel com Turbo Boost, até 512 MB DDR5 de RAM vídeo
1624 Perguntas Visualizar todos
Need to re-solder some Resistors & Capacitors - Water damage
Hello, my friend gift me her MacBook Pro mid 2012 13" water damaged.
(Magsafe blinking light - no power on)
I have checked and cleaned the logic board but there are missing the following:
  • R 5369
  • R 5099
  • R 5053
  • R 5076
  • C 4905
  • C 4910
Where can I buy ? How can I understand the value of parts?
Thanks
Update (11/07/2017)
Also missing - ARE THEY REALLY NECESSARY?
  • R 5339
  • R 5349
  • R 5290
  • R 5001
  • R 5024
  • R 5023
  • C 7408
  • C 7414
  • C 7415
  • C 7416
  • C 5520
  • R 5021
  • C 7419
  • C 7418
  • C 1675
  • C 1673
  • C 1674
  • C 1671
How can this system have worked if all those parts are missing?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Those parts are there for a reason. You can do without some of those capacitors but you NEED all the resistors! You can get the values on the schematic but it would be better to buy a donor board to steal the components off of. Look for your 820- number but I already know yours is a 820-3115 and get one from china. They are cheap then just steal what you need off the other board. You will need a hot air station and a microscope.
Esta resposta foi útil?
Pontuação 3
1 comentário:
Thank You so much :)
por
Pergunta mais útil
download this schematic https://mega.nz/#!eggVQTSQ!h-bKyiA8hM_ka.... open it with acrobat reader dc and it will let you search for the components and tell you the values
Pontuação 4
3 comentários:
Thanks for fast reply!
I have booted this Mac two days ago ( in SMC bypass). And it has Booted normally after I had used a new magsafe. But just one normal boot - now I have blinking Magsafe led and no Power.
Is it possible that my MBP model don't need all those missing capacitors?
Thanks
por
did you try disconnecting and reconnecting the battery
por
yes, also changed Magsafe and DC In Board. Tried any key combination and Smc reset via command line (when I was able to Boot via Smc bypass)...nothing.
por
Adicionar a sua resposta
LORIS GIAMMARINO será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 4
Duração total: 149
