Ir para o conteúdo principal
Part of the Lenovo G Series of everyday laptops released in November 2012.
23 Perguntas Visualizar todos
The power input on laptop has come loose
The input jack bit on my lenovo g580 has come lose and now moves away when i try to connect it to the power lead, anyone have any idea of how to fix it back in place, it's attached to the usb ports on the side that are also loose.
I've tried bracing it with some plsatic and gluing it in place but it wasn't strong enough
Cheers
Esta pergunta é pertinente?
Pontuação 0
Adicionar um comentário
1 Resposta
Solução escolhida
What glue did you use? It sounds like a piece of plastic holding the jack in place has got broken. You may find that 2-part epoxy resin will be more successful as yo can use the not only to stick with, but also to fill a void left by the broken plastic. But you'll have to reassemble the case before the epoxy goes rock solid as you may have to shave off any excess.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Joshua Clay-Dennis será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 68
