Ir para o conteúdo principal
Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
544 Perguntas Visualizar todos
Can the logic board be repaired
The computer will boot. To the user selection page. It displays vertical alternating blue/light blue bars. After entering password it begins to load, then goes to a solid crisp grey screen. Then it shuts off or reboots to same user screen.
This had been an intermittent problem until now.
Apple says they don't repair "vintage machines" but says it needs a new logic board.
Can this logic board be repaired?
Update (11/06/2017)
This is a late 2011 MB Pro.
I've tried plugging it into an external monitor and this happens:
On the computers screen the same vertical bars and when I type in login info the screen goes grey but has double images.
The loading bar continues to the point where screen goes black then comes back on with the proper and clear background image and begins to load programs.
This is when the second monitor detects a signal and shows the same thing.
I got as far having everything load then closed a window then the computer just shut down. I don't get this far without plugging in the external monitor.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Pergunta mais útil
The 17" models are still highly sought after so its worth repairing! Even a Core 2 Duo system.
Let's see if we can localize what part/s need replacing here. Are you able to boot up holding the T key at the startup bong? You should see a floating FireWire symbol on the screen do you see it at all? If you do lets try plugging in an external display does the that look good?
Esta resposta foi útil?
Pontuação 1
3 comentários:
We need to know the exact machine and if it is one of these: MacBook Pro (17-inch, Early 2011) and MacBook Pro (17-inch, Late 2011). If so it is probably the GPU. See this old Apple program: https://www.apple.com/support/macbookpro...
I will be working on one of these this week for a possible work around.
por
OK your testing aims us to a GPU issue Mayer pointed out.
But, I still want you to try going into Target Disk Mode So when you hear the startup tone you press the T key do you see the Icon on the screen? This test tells us if we can force the system into low res mode.
por
@mayer - Don't forget this program has ended as the discontinued support last year on this model.
por
Got much the same problem with mine, except mine has pink and white bars,
it was fixed by IT Online in Melbourne, Australia last year for over $600 and had the mother board replaced, lasted a day or so then blew up. They repaired it again under warranty and it lasted past the warranty expiry date then blew up again!
Is there anyone competent out there who can fix these things properly?
Pontuação 0
Try removing the logic board and remove the heatsink, heat the GPU with hairdryer for 5-6 minutes. Reassemble and try turning on the computer. If it works and I suppose it’ll work, then it means the problem is the GPU.
Pontuação 0
Adicionar a sua resposta
Tim Hagen-Foley será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 2,591
