Ir para o conteúdo principal
Bissell's Bolt ION 2-in-1 Cordless for large rooms or smaller areas with detachable, handheld vacuum. Model number: 1312.
Why is dirt escaping from my vacuum?
The dirt is spilling out of my vacuum and will not suck in more dirt.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Dirt may be escaping from your vacuum due to one or two things:
1. The filter on the inside of the dirt trap bag may be loose or unlocked. This may cause dirt and dust to flow freely and escape through either the detachable portion of your vacuum or the end by the head and brush roll.
2. Your handheld portion which holds the filter may be loose or detached at a certain point. Re-check to make sure that it is secure and fastened.
Hope this helps.
Ben
Esta resposta foi útil?
Pontuação 0
1 comentário:
Ok, how do I fix this problem ?
por
Adicionar a sua resposta
jasmine soria-gamino será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 244
