Ir para o conteúdo principal
Case for the iPhone 6s, launched by Apple in December 2015. The Smart Battery Case includes an integrated battery to boost the capacity of an iPhone 6s.
I dropped it in water and now not working
i dropped in water along with phone, phone is working fine but smart battery is not charging and if I plug iPhone 7 in it , smart battery is heating and phone discharging. i tried to charge the battery separately there is no sign of charging.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
The iPhone has IP67 water resistance, not the case. There is most likely a short.
Esta resposta foi útil?
Pontuação 0
Should I use the heat or cool option on the air dryer to air dry the charging case I need a an anser as soon as possible
Pontuação 0
1 comentário:
Heat but don’t use too much heat or you may cause a swollen battery.
por
Adicionar a sua resposta
ALSABT Dubai será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Ao todo: 2,702
