Ir para o conteúdo principal
3d touch and touch id not working..
The touchscreen i.e. 2d touch of my phone works fine but the 3d touch isn’t responding...?
I tried reseting the phone but it just avoids to work..
Even the Touch ID is not working even though the home button works just fine but the finger print isn’t sensed......
I had a screen replacement once.
I would be nice if you help me in finding the problem with it...
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
4 respostas
Solução escolhida
Hi,
Both the 3D Touch and home button run through the same cable, I would highly suggest trying another screen, as there may be damage in the cable. :-)
Esta resposta foi útil?
Pontuação 3
3 comentários:
Are you sure as I have problem only with my Touch ID but the home button still works.
por
Yes, I am quite positive, try another screen and let me know, also make sure it’s not a poor copy screen
por
Sure will do that..!
por
I had the same problem, and after i replaced it with the old screen it all worked and I found out that some how the little cable was broken:(
Pontuação 1
1 comentário:
I e replaced 2 screens and still can’t get working properly
por
I have 3Dtouch, touchID and force touch not working after I opened My iphone7plus, maybe changing screen I can solve the problem ?
Pontuação 0
1 comentário:
I’m pretty sure you have damage one of the flex cable ( the lower one) it’s very easy to . i have done it a few times:( So you you have to be very very very carefull when you open up your phone.
por
I have this problem too with my iPhone 8 Plus, the flex cable doesn’t even seem damaged at all.
Pontuação 0
3 comentários:
It is for sure damaged, change backlight and all will be right
por
When I opened my 7 plus I couldn’t see broken flex till I put away backlight screen protection. If you opened your iPhone and from that moment Touch ID and home button doesn’t worked anymore, is for sure the damaged flex. Don’t change any other things, don’t’ change home button, just be very very very careful and change back light. By change only back light your screen will be good as usual. if you change all the screen with a preassebled as GIGA FIXXO ON AMAZON, it will be very easy and secure, but you will not have the original qualiti of apple screen
por
Attention, flex Brocken is not the one you see near the home button!! The flex Brocken is under the protection of the screen. Don’t do it by yourself become is too risky, go to a Chinese or to a Irepair, and say that you want change backlight (15€ Part cost)
por
Adicionar a sua resposta
Shivam Patil será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 20
Ao todo: 3,366
