Ir para o conteúdo principal
Apple AirPods are wireless headphones released December 2016.
20 Perguntas Visualizar todos
Help I washed my airpods in a washing machine
Guys my AirPods and airpods charging case I washed it in a washing machine bymistakely forgot I had it in my pocket help…the green led light is not illuminating it doesn't work help if any one has any solution about it plz do share
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
My suggestion would be to put them in a bag of rice overnight. The rice will help draw out the water. If this doesn't work then I'm afraid you will need to buy a new pair since the water has likely killed the electrical components. It might also be worth letting them stay in the bag of rice for a few days. Good luck!
Esta resposta foi útil?
Pontuação 1
2 comentários:
That is a myth. Rice is not a desiccant, and only blocks air flow. Keep them warm with a lamp and fan.
por
I save those little packets of stuff that keeps stuff dry hahaha u know the little bags of it says don't eat blah blah n I have a med bottle full I used bef
por
Adicionar a sua resposta
Ali será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 10
Últimos 30 dias: 29
Duração total: 27,599
