Ir para o conteúdo principal
Model M8413 or A1007 / 600, 700, 800, or 900 MHz G3 processor
Replacing iBook G3 14 800Mhz Logic Board
Have a iBook G3 14" 800Mhz that I need to replace the logic board. I have a replacement 800Mhz logic board, but it seems that on the new board, the contacts for the battery are right on the board, rather that a plug where you attach the connector to the battery terminals. These contacts for the battery do not seem to line up where the battery would be anyway. I have worked on a few of these machines but have never seen this before.
Has anyone seen this before and do I need some other part to install this board.
Thanks!
Esta é uma boa pergunta?
Pontuação -1
2 comentários
I am not sure which board that I have. I cannot find those numbers anywhere on the logic board.
por
OK, it seems that the replacement logic board is the 661-1779.
por
Adicionar um comentário
2 respostas
Solução escolhida
You received a 12" ibook G3 board. Return it and ask for a 14" one.
Esta resposta foi útil?
Pontuação 1
Pergunta mais útil
There were two logic boards for the 14" 800 MHz G3
661-2678 (16 VRAM)
661-1779 (32 VRAM)
There were also two 800MHz logic boards for the 12" models. What do you have?
Pontuação 2
3 comentários:
It is the 661-1779
por
I examined the photos you emailed me and the boards just don't seem to be interchangeable. I would return the board and get the correct one.
por
Thank you, that seems to be it.
por
Adicionar a sua resposta
studio58 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 18
Ao todo: 1,019
