Ir para o conteúdo principal
Touch ID not working after replacing home button cable
Hi, I recently replaced my home button cable after accidentally ripping the home button cable while replacing my phone's screen, I bought this part https://www.amazon.com/dp/B00XNA80Z6?ref... After successfully installing it, I found the the home button works too go home and things like that. However the touch ID does not work. Any suggestions?
Thanks
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Unfortunately, only the original home button will work for TouchID. The home button and logic board are paired, so you'd have to replace both if you want TouchID functionality. Here's another discussion about it in case you're curious: Any possibility to replace Homebutton AND have Touch ID still working?.
Esta resposta foi útil?
Pontuação 2
2 comentários:
UPDATE: I just found this article that shows a glimpse of hope on the horizon (pun intended): https://ios.gadgethacks.com/news/after-e...
por
Oh I had thought since it was just the cable or would be fine
por
Adicionar a sua resposta
Monica Alexander será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 6
Duração total: 5,979
