Why is tape/glue strip so bad?
Why is tape/glue strip so bad. It doesn't stick even after cleaning with alcohol.
Esta é uma boa pergunta?
Alcohol typically ruins adhesive. Ifixit recommends replacing those strips:
Esta resposta foi útil?
I would add you need to apply pressure in one direction around as you apply the cover glass and keep it under pressure for a good 12hrs to let cure. Here's a good vid of us checking out different methods: EP65 Conclusion to the iPad Sealing Workshop at the iFixit Unconfrence
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Ao todo: 113
