Ir para o conteúdo principal
The Toshiba Satellite M45 Laptop is designed for powerful, portable, multimedia computing. It features a 15.4” WXGA Display running Microsoft Windows XP, with 1.6GHz Processor, 512MB RAM, and 80GB Hard Drive.
13 Perguntas Visualizar todos
Why does my laptop shutdown or even won't turn on?
My laptop is acting strange, when a I remove the battery and plug the ac cord can not be turn on, as is no ac power is connected, I disconnect and connect the ac power until the blue leds turn on and then it starts up normally windows xp, but all of a sudden it shutdowns turning off everything.
please help to determine if this is a motherboard issue.
Esta é uma boa pergunta?
Pontuação -1
2 comentários
armando, does it function normally on battery power?
por
No with the battery it won't turn on
por
Adicionar um comentário
1 resposta
Solução escolhida
armando, you might just have a battery that is not being charge or not holding a charge. Check the troubleshooting instruction out on here Toshiba Satellite M45 Troubleshooting and let us know if that is helping you out and if not get back on here so we can further assist you. Good Luck
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
armando será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 728
