want charge or power on
Plug phone in charge don't show charg
er light and want charge or anything no water damage screens not cracked or anything
Esta é uma boa pergunta?
u need a new micro usb charging port.
Esta resposta foi útil?
U22 shows only charging ,but wont turned on.
Try a different charging cable if that doesn't work clean the charging port and have a look for any bent pins on the port. It could be the battery has died or charging port dirty or faulty. Get a battery try that if that doesn't work you will need a new charging port
Boost battery first.if not ok check software
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 9
Duração total: 713
