iPhone Replaced Battery now sleep/wake button and video mic won’t work
Recently replaced my iPhone 6 battery. Now the sleep/wake button won’t work as well as faint-scratchy/no sound recorded on videos.
Esta é uma boa pergunta?
Ok, I should've just posted my answer earlier. So you've damaged some stuff while doing your repair. The power button, which is connected to the volume/mute, which you'll have to remove the battery and the logic board. It's a pretty big repair. Youve also likely damaged the front camera flex assembly. Not that big of a job. I mean you should check that and make sure you properly seated the connections. But likely you'll have to order new a new one
iPhone 6 Power Button Cable Assembly Replacement
Substituição do cabo da câmera frontal e de sensores do iPhone 6
Produto
$19.99
Produto
$9.99
Guia
Nível de dificuldade:
Difícil
1 - 2 hours
Guia
Moderada
30 minutes - 1 hour
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 15
Duração total: 226
2 comentários
Does you volume/mute switch work?
por iMedic
Yes it works.
por eric collins
