Ir para o conteúdo principal
Announced on October 16, 2014, identifiable by the model number A1347 and EMC 2840.
RAM beep codes on 2014 Mac Mini
I have a late 2014 mac mini that is giving me 3 beeps on start up. Traditionally this a ram issue, is there anyway to save this computer, as the RAM for this machine is soldered to the board?
Thanks in advance.
Esta é uma boa pergunta?
Pontuação 1
2 comentários
In a desperate attempt to salvage this thing I figured I might as well try to hit the solder connections with some rubbing alcohol and it worked?! YAY!
por
Congrats! Hopefully that fixed whatever issue the RAM was having!
por
Adicionar um comentário
2 respostas
Pergunta mais útil
If the RAM has failed there is nothing you can do as Apple Soldered the RAM in ;-{ Sorry.
Here's the beep codes to be doubly sure: About Mac startup tones.
Esta resposta foi útil?
Pontuação 1
Hi Taylor,
Sorry to hear that you're having RAM issues, @danj's post regarding beep codes most likely proves there is an issue with the RAM. However, we do sell replacement logic boards for that model of computer if you're interested. Currently, they're out of stock, but I know we have one arriving early next week.
- Jasen
Imagem de Replace a logic board (motherboard) compatible with the Mac mini (A1347, model MGEM2LL/A) small desktop computer. Fix processing issues like unexpected shutdowns, reboots or water damage.
Produto
Mac mini A1347 (Late 2014) Core i5 1.4 GHz Logic Board
$174.99
Pontuação 1
Adicionar a sua resposta
Taylor Struna será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 9
Ao todo: 1,657
