Why is there no power to the iron. No indicator light on.
Whilst ironing the power light went off and iron stop working.
Esta é uma boa pergunta?
Many of the UK heating devices have a fuse within the plug. Carefully open the plug to gain access to the fuse. Here's an image of the plug assembly from the Morphy Richards Iron Teardown:
While not stated you'll see the far left & right connectors are also the fuse clips. With an Ohm or continuity tester you should see these are connected (with a fuse in place), If not you need a new fuse.
Esta resposta foi útil?
1. check the cord
2. there is a fuse in the steam iron press, get it replaced by service centre.
4. Thermostat is not working.
4. heating rod is damage.
Where can I get my iron seen to ? Rescaled it now won’t come on just keeps going off checked fuse new fuse in but still not coming on !
I have a problem about my steam it is those not indicate of lights
You might have experienced a power issue. Here are a few steps you can take to troubleshoot the problem:
The iron might need professional repair or replacement if these steps don't fix the problem.
Últimas 24 horas: 23
Últimos 7 dias: 118
Últimos 30 dias: 478
Duração total: 28,333
3 comentários
I have lefty iron forgot to turn off just noticed but the iron is off and now won't work
por Susan Bracken
I’ve a steam iron generator it’s stopped workin the light doesn’t come on no heat nothing can u help?
por tina.kavanagh@hotmail.co.uk
My iron won’t switch on .. change the fuse
por roseann01
