Ir para o conteúdo principal
Error -1 iPhone 7 plus
a customer brought in a iphone 7 plus for a screen repair, but it had a broken lcd so i was unable to test it before i opened it. (note ive fixed about 30 7/7plus without issues.) anyway after installing the new screen I found the phone lagging and freezing up. but it wasnt my screen because the power button was also lagging and when i opened voice memos the record icon was unable to be pressed, also i only use oem apple lcd replacement parts, refurbished by myself so i know they arent fake. anyway I tried to restore the phone to see if that would fix it because i know there have been alot of issues with ios11 and im getting error -1 and now the phone is stuck in recovery mode...if tried updating/and restoring in dfu still not working. another note i tried both itunes and 3utools. when i flash on 3u i can see that it fails at 80% when trying to flash fuddata.
Esta é uma boa pergunta?
Pontuação 3
3 comentários
Will jailbreaking at least get it running? I don't care if I can't make phone calls
por
Replacement U3601 will solve the problem
por
Евгений Сухарев excellent bro .
i am at turkey . everytime you can take free beer by me
por
Adicionar um comentário
4 respostas
Pergunta mais útil
Change IC u3601 and flash firmware again
Esta resposta foi útil?
Pontuação 2
1 comentário:
I hope I’ve seen your comment earlier, so it would save me hours of checking and fix.
por
This is a pretty old error code. Try this
https://m.youtube.com/watch?v=8OYjEP8xtB...
Pontuação 1
5 comentários:
Lol its an iPhone 7 plus on iOS 11.. I highly doubt that program is even compatible.
por
Any luck on this !?also got the exact same problem and I'm there's no one here that can do micro soldering
por
@theimedic -- HEY How's it going, long time no see. You Ok?
por
It was audio ic
por
How to fix this? Thanks
por
This is the classic error code for baseband issue now recalled by Apple on iphone 7 Model A1660 only. You need to take it to a real Apple store and they will send to Apple to determine replacement eligibility.
https://www.apple.com/support/iphone-7-n...
Pontuação 0
iPhone error 1? Joyoshare Ultfix can help you repair it without data loss. I used it to do the same.
Pontuação 0
Adicionar a sua resposta
lukerockhill será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 30
Ao todo: 7,643
