Ir para o conteúdo principal
Samsung's flagship phone, the Galaxy S8. Released in April 2017.
Lcd or just screen replacement
I recently dropped my galaxy s8, and in the area it cracked there is a significantly large black spot, which has made only the top of my screen unusable. If i replace the screen only will it fix the problem, or do i need to replace the phone itself. Money is more of an issue than anything, and ive replaced phone screens myself in the past, but never an lcd
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
You need a new LCD. Honestly the LCD replacement isn't bad. If the LCD is many going to be used, I don't even use heat anymore. I just rip it out and put the new one in
[produto vinculado ausente ou desativado: IF355-001]
Samsung Galaxy S8 Screen Replacement
Esta resposta foi útil?
Pontuação 2
2 comentários:
I honestly just dont have 300$ for a new one
por
sorry. Your LCD is broken. That's why you need to replace. You can try and get a cheap one, but cheap parts almost always yield cheap problems
por
Adicionar a sua resposta
Mykenna kemling será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Ao todo: 1,706
