Ir para o conteúdo principal
As versões B6 e B7 do Volkswagen Passat são automóveis familiares de grande porte com motor dianteiro produzidos pela montadora alemã Volkswagen. A linha B6 do Passat foi produzida entre 2005 e 2010, e a linha B7 foi produzida entre 2010 e 2015 como uma reestilização da linha B6.
Key fob stuck in ignition
Just replaced the battery in my key fob. I got into my car with the normal key, put the fob in the ignition and now it won't come out. Evidently I need to reprogram, but how can I get the key fob out?
Update (10/20/2017)
I realized my car battery was the issue. It was flatlined.
Left headlight was staying on even with key out.
So that seems to be the main issue.
I was able to get the key fob out after jumping the car.
So just trying to find a solution now for the headlight issue.
May disconnect headlight for now so it doesn't continue to drain battery.
Esta é uma boa pergunta?
Pontuação 3
3 comentários
this worked for me omg thank you so much
por
Glad it worked, pass it along...
por
Adicionar um comentário
3 respostas
Pergunta mais útil
Push on brake and hit button forgear shifter a couple of times.
Esta resposta foi útil?
Pontuação 2
3 comentários:
Yes, I had tried this already but it had not worked for me.
I had seen a video showing that.
It would have been great!
Thanks
por
It worked for me. Thank you!!
por
Its answer is pretty simple.
Move your car backward and forward again.
Make sure your handle face front. DO NOT LEAVE YOUR CAR WHEN YOUR WHEEL IS TURNED.
Pontuação 0
2 comentários:
I was programming my remote key fob now the fob is stuck in the ignition
por
I was programming my key fob and now the fob is stuck in the ignition I can’t get it out
por
Is there a battery in the fob?
If the five won’t come out of the ignition?
Pontuação 0
Adicionar a sua resposta
Darby Rosello será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 10
Últimos 30 dias: 41
Ao todo: 22,434
