Ir para o conteúdo principal
The 2003-2005 Pontiac Sunfire is a more streamlined updated version of the popular car.
Why is there gas spraying into the tube that leads to my air filter?
There is a small black hose that leads to the tube my air filter is in & the other end is on a cyndrilical metal like item...something to do with fuel I'm guessing. Gasoline comes out the end that goes into the tube that leads to my air filter, my car popped & started smoking the other day after I tried to start it, I took the air filter out, the small black hose off & plugged it up...help! What is the metal cylinder shaped item that the other end of the hose i's hooked up to called?
Thank you.
Esta é uma boa pergunta?
Pontuação 0
1 comentário
@bsrigamarowe post some good pictures of what you are looking at with your question. That will allow us to see what you see. Use this guide Adicionar imagens a uma pergunta já existente for that.
What exact year is it and hat engine size does it have?
por
Adicionar um comentário
1 resposta
Solução escolhida
The only line that should be attached to the air intake is the pcv exhaust . Are you sure this has gas coming out or is it oil . you may need to replace the pcv valve if your getting excessive blow by. The cylindrical item is the PCV valve . Hope this helps
Esta resposta foi útil?
Pontuação 3
2 comentários:
It is definitely gas, my air filter was covered in it which is probablying why it popped & was smoldering when I tried to start my car. When I had the hose attached it was my car had a difficult time starting, I had to pump on the gas pedal & when I'd let up it'd start. Now that it's disconnected it starts just fine.
por
@bsrigamarowe could you post some photos of the part your talking about
por
Adicionar a sua resposta
Bernard será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 35
Ao todo: 2,963
