Ir para o conteúdo principal
Repair guides and support for desktop computers produced by Asus including towers and all-in-one display PCs.
How can I add more memory?
Asus Support site says to not open the cover, work should only be done by "licensed" technicians. Heck I'm A+ certified (I do networking though), even that yielded no info. Anyway is there a way to see ahead of time /pre-cover popping, what I can add as far as memory? I just want to make sure I buy the correct kind.
Thanks!
Esta é uma boa pergunta?
Pontuação 0
3 comentários:
Please tell us your exact machine.
por
Sure, but we'll need a bit more here... How about the model info? Asus has a few different models.
por
@nykathy did you find your answer? If not give us your model number so we can provide it for you.
por
Adicionar um comentário
1 resposta
I used to use BelArc Advisor, it will list RAM type, size and speed. https://www.belarc.com/products_belarc_a...
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Kathleen Brown será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Ao todo: 104
