How do I troubleshoot my display problem?
I have followed the guides, got the part numbers, replaced the inverter board and display.... Still no dice :( I'm out of luck and could really use some advice. Thank you!!
Esta é uma boa pergunta?
First thing to do to is to try to isolate the problem. Hook it up to an external monitor and see if you get anything. Next put it into Target Mode by hooking it up to another Mac via a firewire cable and start the iMac holding down the "T" key and run disk utilities on the the hard drive from the other machine.
Esta resposta foi útil?
Mayer, Thank you for your help! The machine will not send a signal to an external monitor OR boot in target mode... What should I do next?
Also, on the main board I see two of the four diagnostic LEDs lit when powered on, if this helps.
Which LEDs are lit?
Numbers 1 & 2
This indicates that the power supply is fine. I guess there is a problem with the GPU or other vital part on the logicboard. Check for leaking or bulging capacitors. Sometimes a reflow of the GPU helps. If there is enough demand i might write a guide to this topic, done it a few times successfully.
maybe you must change the mobo.
I believe your log in name is very misleading on this site and infers an authority you do not have unless you represent Corporate Apple. Please change it to something that is less deceiving.
I think you need to give some sort of justification for your advice "Apple". Are there no other troubleshooting tips you could give first??????
Ya. I installed a new logic board! Running like a champ! Thank you all for the awesome advice! @Apple your log in is a little misleading, coming from an Apple fan of course :)
@Mayer you are the hefe!! Thank you for your help!
@Mayer
What do you mean by a reflow of the GPU?
This may solve my problem.
And thank you for being such an incredible source!
my imac 20" then u turn the power on the lcd momentarily lights up then go out the imac boot up and work on the external monitors work fine but the main screen is black
You need to start your own question.
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 3,001
