Ir para o conteúdo principal
The Sony Cyber-shot DSC-HX1 is a digital still camera with a 9.0 megapixel image sensor, 20x optical zoom, and 3.0 inch LCD screen among other features.
Why is my viewfinder& lcd screen blank when turned on?
My camera powers on with a full battery charge but the view & lcd screen is blank! I can go to my photos & see them on the viewfinder & lcd screen perfectly! All the other buttons work fine! I have reset the camera & changed on the battery several times but nothing helps!!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Hi,
Try taking a picture (I realize that you cannot "see'"what you are taking) and then download it to a pc to see whether you have a picture or just a black image.
Esta resposta foi útil?
Pontuação 2
The same problem appeared on my DSC-HX1 camera. With some hardware hack, you can fix the problem:
https://eengineerblog.blogspot.hu/2018/0...
This is written in hungarian, but the key is to change one little resistor on the main board. Replace R444 resistor by a 12kOhm. Good luck!
Pontuação 0
Adicionar a sua resposta
Cheryl Ann Mewbourn será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 17
Ao todo: 1,505
