Why won't my device turn on?
Even when I charge my device, it won't turn on. What could be the issue?
Esta é uma boa pergunta?
The device's battery may be worn out and unable to recharge. To replace the battery, you will need to remove the bottom panel of your 2DS XL Device. After the panel is removed, you will have access to the battery and can replace it. For further help with replacing the battery, refer to our battery replacement guide.
Esta resposta foi útil?
try to charge the nintendo. Its probably out of battery.
try to go to the service centre. They will tell you what's the problem
try to change the battery.
or, try to service the screen. It may be broken.
if the screen(s) were broken the blue light would still turn on, and you would hear sound
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 13
Ao todo: 4,888
1 comentário
Mines does that to I charge to fill battery and it does not come on
por Aliyah Prewitt
