Ir para o conteúdo principal
The PowerShot S110 has a 12.1 Megapixel High-Sensitivity CMOS sensor and DIGIC 5 Image Processor, 12-bit multi aspect RAW+JPEG, 24mm Wide-Angle, f/2.0 lens with 5x Optical Zoom and a sleek pocket-sized body.
6 Perguntas Visualizar todos
I read that a microswitch may be missing
I have a S110 that doesn't power on, battery is good. I've read elsewhere that there should be white micro-switch under the battery cover that may be missing. Is this a DIY repair, urban legend?
Thanks,
Alan O.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
in case you haven't tried you can poke around to see if there is anything hidden under a sticker
Esta resposta foi útil?
Pontuação 0
2 comentários:
what sticker?
por
there could be a sticker, perhaps plain colored in the battery cover hiding the switch as this a common way to hiding screws, as i am not familiar with this camera there isn't much i can tell you.
por
Adicionar a sua resposta
Alan O será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 163
