Why half of the screen is not working properly and how to fix it?
Esta é uma boa pergunta?
my guess is that it is either a screen rotation glitch which should be fixed by turning the phone off and back on, or the screen is dieing and you should see if the phone is under any kind of warranty. if not then look for a replacement screen but i got a feeling that it is just a screen rotation glitch
Esta resposta foi útil?
If half of the screen is “not working” or showing “white noise”. It’s about the display cable connecting to the mainboard. Maybe only the plug went loose, try wrench / press the phone where that connector is located: it’s on the right side about between the volume and power power button. With a little luck you can fix it for a while without opening.
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 18
Duração total: 4,108
3 comentários
I suddenly droped my phone and now, My screen was not working :( sucks. :( My half screen is not working and the half is working.
por glydellao
Thanks it worked perfectly..!!!
Half of my screen went black
I turned it off and put it on and it worked.
Gracias..!!!!!
por bigbamo
Half of my screen in not working and certain letters, what I’m doing rn is holding down my emoji key and switching it to one side. Does anyone know how to fix that?
por Eryn Perkins
