installing memory in 2133
when I install new memory 4 gb 2x2 imac does not work, when I put the original 1gb back it works.
any suggestions?
Esta é uma boa pergunta?
any suggestions?
have you confirmed you have the correct type of RAM for your model iMac?
the Mid 2007 20" 2.0GHz/2.4GHz iMac uses PC2-5300 (667MHz) DDR2 SO-DIMM memory
the Early 2008 20" 2.4GHz/2.66GHz iMac uses PC2-6400 (800 MHz) DDR2 SO-DIMM memory
Esta resposta foi útil?
Make sure you're inserting it correctly too.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 2,134
