How to repair damaged power port
How to repair or replace battery charging port
Esta é uma boa pergunta?
from your question there is no way for me to tell exactly what the power port you need repaired is on.
if it's a phone, a calculator, or? and what model. there are a lot of things with power ports, some are much easier to fix than others. Most likely though, it's best to remove the old one after buying a new one and then installing the new one. I know that sounds impossible with some Items but you have to remember, it was installed once and so you know it can be installed again, It's just a matter of getting it done.
Esta resposta foi útil?
ZTE N817 will not charge. It is not the cord. I used to be able to giggle cord and get it charging..cellphone
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 7
Duração total: 188
