Ir para o conteúdo principal
The Toshiba Satellite Click 2 Pro is a 13 inch simple and easy to use hybrid laptop, created by Toshiba in 2014
14 Perguntas Visualizar todos
expandig the RAM more than 4GB?
Can i expand the ram more than 4GB on this device ?
Update (09/28/2017)
SATELLITE CLICK 2 L30W-B-104
This is the device name and you can find all the information in this site
http://www.toshiba.co.il/en/discontinued...
.. The company says that the maximum ram is 4 gb is this true...
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
I can't find any documentation for your exact model are you sure the model info is correct here? Where did you buy it and when? Can you at least tell us the CPU info is it a Celaron or Pentium.
Is this your system specs? Toshiba Satellite l30W-B
Here is a similar system teardown: Taking apart Toshiba Satellite L35 and L30
Update (09/28/2017)
Sorry to say the click series has soldered RAM as you can see here:
So no you can't upgrade it from what it was shipped with.
Esta resposta foi útil?
Pontuação 2
I'm lucky enough to have 8 gigs of RAM on my motherboard but I'm wondering what that empty open slot is for right below the wireless card?
Pontuação 0
Adicionar a sua resposta
Ziad Nattouf será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 539
